주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년에 출시된 6세대 ThinkPad X1 Carbon은 Lenovo의 인기 있는 고성능 비즈니스 노트북 중 하나입니다. 모델 번호: 20QD000BUS
Charging on and off
When I plug the charger to my laptop its charging then suddenly not charging and its repeating just like that
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @aaronfresnido
You need to prove whether the problem is with the charger or the laptop.
Connect the charger to a mobile phone which has a USB-C type charging port and check if the phone shows that it is behaving the same as the laptop i.e. charge on, charge off or whether the charge stays constant.
If the charger is OK it could be a problem with the USB-C charge port in the laptop (loose?) or somewhere else on the motherboard.
Here's the hardware maintenance manual for the laptop that will help you to gain access to the motherboard so that you can check if the USB-C port is securely soldered to the board or not.
If the USB-C port is OK and if the motherboard is model number NM-B481 (model number is printed on the board itself), here are the schematics. The battery charging circuit is on p.65 (of 88 pdf)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Aaron Fresnido 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 69
