주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung 식기세척기 수리 정보입니다.
Samsung dishwasher auto light blinking
Hey guys, my Samsung dishwasher auto light blinks after the wash cycle when reaching the rinse cycle. Each time, I can simply switch it off and switch it on then start a new full cycle without issue.
I've read that it's an issue with the water supply, but I don't understand how it wouldn't fail on the initial wash cycle, or why it doesn't fail at all on the subsequent run.
I tried priming the hot water beforehand and during the cycle to make sure hot water is always available, but it didn't work.
What should I do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi @charlesmat24088
What is the model number of the dishwasher?
Hey @jayeff model is DW80J3020US
댓글 달기
답변 1개
가장 유용한 답변
Hi @charlesmat24088
See p.59 (61 of 89 pdf) in the service manual for how to enter the Service Inspection mode and perform mode 1 checks.
On p.61 (63 of 89 pdf) it details how to check the if the water inlet system is OK.
There's a mention of a flowmeter which measures the amount of water entering but I can't find it in the manual except that it connects to the control board on the control board connector CN301 pin 5 - see p.81 (83 of 89 pdf). Usually flowmeters are a reed switch which is magnetically operated by a turbine wheel with a magnet attached which is in the flow path. As the wheel turns it causes the reed switch to send pulses to the control board which counts them to know how much water has entered the machine.
Have read that it is located near the water inlet valve. Just mentioning this if all the other tests prove OK.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks @jayeff, I will start troubleshooting!
댓글 달기
답변을 추가하세요
Charles Mathieu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 17
전체 시간: 92
