주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이중 동작 교반기가 장착된 3.5 입방피트 상부 적재식 세탁기. 2016년 출시.
Stuck on final rinse, LED flashing
Hello. I was originally getting a flashing LED for Final Spin and it wouldn't progress past it.
I would try to press drain/spin and it will only drain a bit and then not spin.
I have replaced the shift actuator, splutch kit, and capacitor(even though old one was good).
After replacing the parts I have done a recalibration and the issue still persisted.
I went into Diag mode and got a code F7E1 for Basket speed. During Auto test it went through it completely fine.
In manual mode it everything seems to work except for it being on "LowSpin/HighSpin" where I get nothing. Agitation mode works fine. The windings of the motor were in spec as I was going through trouble shooting steps.
I'm currently at the point where I'm trying to check voltage on J12 / J2 connector. My multimeter isn't thin enough to backprobe the 4 pin J12 connector.
What else can I do to fix this washer?
Also when roommates use the washer it's sometimes unbalanced and clunks until we stop the cycle and rebalance the load. Tub suspension bolts seem intact by the way
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @aceb56029
Follow the tachometer verification test as per p.5 of the tech sheet and check what you find.
이 답변이 도움이 되었나요?
점수 2
댓글 7개:
Sorry I did also do this test before and forgot to mention. As I slowly turned the basket the LEDs lit up at each cycle
의 공유
@aceb56029
If it passes all of the Test #3B drive system tests (p.14→p.16 in the tech sheet) it looks like it might be a main control board problem, unless the drum is binding as it rotates.
Did you check that the drum rotates smoothly when you manually turn it?
Also did you check all 4 suspension rods to make sure that they're all OK? Test them by pressing down hard on the tub and then release it and check if it quickly returns to normal and then stops or whether it bounces up and down for a little bit.
If it bounces a few times, one or more of the rods has lost tension. Search for W10780045.
They come as a kit of 4 rods so you may have to replace all anyway.
의 공유
The drum does rotate smoothly. Only thing is it hums when it's time for a final spin.
How am I supposed to backprobe the J12 connector to test it? The J12 connector is at the bottom of the board at an awkward angle and isn't like a "normal" 4 pin connector that my leads can backprobe
의 공유
Also all the tension rods rebound fine without excess
의 공유
@aceb56029
Use the wiring diagrams in the tech sheet to see what the J12 pins connect to and then see if the corresponding connection on wherever it connects to is more accessible e.g. J12/1 → Shifter Assembly pin 2 etc
의 공유
댓글 2개 더보기
댓글 달기
답변을 추가하세요
Ace B 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 52
전체 시간: 249
