주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
수냉식 Porsche 911의 1세대인 996 시리즈에 대한 수리 안내서와 지원 정보를 제공합니다.
Stop light not working
Right stop light not working, my 996 has aftermarket LED tail lights, I replaced both unit door new ones and the problem continues..
All other lights work fine (turn signals, hazards, reverse, night lights)
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Thank you! I checked for 12v on tje 4 pin at the light with the brake pedal pressed without any luck… will have to trace that 13 connection… doesn’t look like a fun task, specially with no electric experience…
의
댓글 달기
답변 1개
선택된 해법
Hi @diegoestra71869
Check if there's 12V DC on pin 4 of the connector that the right tail light assembly cable plugs into, when the brake pedal is operated.
If there isn't and since the left side brake light is working, there may be a wiring problem between pin 4 on the connector and the multiple wiring connection point # 13.
Unfortunately I don't know where that is located. You may have to trace the harness wiring back from the right side (or the left side) tail light assembly.
Here's an image of the relevant part of the wiring diagram that may help.
이미지
(click on image)
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Diego Estrada 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 33
전체 시간: 116
