Not switching my phone
When iam doing charging it just vibrate it will not will not on the phone and I remove from charging and try to switch on it will just vibrate and not showing anything
좋은 질문입니까?
좋은 질문입니까?
@saimashaikh "it just vibrate it will not will not on" what you are describing are the symptoms of a failed screen. Replace the display and re-evaluate.
Use something like this video as your guide. Of course you can also use the guide from here. It is written in French. Use a browser that does the translation for you, if needed. Replacement displays are readily available. Just do an online search and select a vendor that appeals to you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem with their device as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 42
