No light when charging
Unit sat for along time and now it won't charge
좋은 질문입니까?
@alantordoff possibly an issue with the battery having discharged below it's charging threshold. That basically means that the battery has discharged to a point where it no longer accepts a charge. I would start of with a new battery. Use this guide Sony WH-1000XM4 배터리 교체 for that.
A new battery will also give you a known well starting point should it become necessary to troubleshoot further. If the new battery doesn't fix this, you will need to check the charging port and charging circuit.
이 답변이 도움이 되었나요?
지난 24시간: 2
지난 7일: 15
지난 30일: 52
전체 시간: 155
