주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
C/K는 1960년부터 1998년까지 미국에서 생산된 쉐보레 및 GMC의 풀사이즈 픽업트럭 라인업입니다. "C"는 후륜 구동을, "K"는 사륜 구동을 의미했습니다. 노후화된 C/K 경형 픽업트럭은 1999년 미국에서 쉐보레 실버라도(Silverado) 및 GMC 시에라(Sierra) 모델로 대체되었습니다.
Break light switch keeps going out
I have a 1996 Chevy Silverado and the break light switch keeps going out. All other light functions work. I have changed it 3 times and each time nothing physically looks wrong with the switch but the lights will not come on. What could cause this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi @bryandaley
If you still have one of the older brake light switches, use a DMM's (digital multimeter) Ohmmeter function to check if the switch is operating electrically OK or not when the switch is manually operated i.e. switch contacts should test 0.00 Ohms when the switch is operated and not OL (open circuit) which would indicate that the switch contacts have burnt out or aren't operating,
If the switch is OK then there's another reason why the brake lights don't work.
Does the switch assembly feel snug and not loose when it is pushed onto the operating rod on the brake pedal - view between 1:38 → 1:48 minutes into this video to see what I mean?
@jayeff Thanks for the information. I don’t have one of the old switches. The switch does fix snug.
The rear light’s weren’t working when I bought the truck. I had to replace the connectors and repair a ground at the lights. After I got the lights working, the break lights still wouldn’t come on. I replaced the break light switch and they worked for about a month. I replaced the switch again and they started working this time about a year. When they quit working. I replaced the switch again and they are working for now.
댓글 달기
답변 1개
가장 유용한 답변
Hi @bryandaley
If it fails again and it's not the switch, here's the wiring diagram for the lights and the brake light switch that may help.
이미지
(click on image)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Bryan Daley 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 26
