주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GMC Sierra 및 VIA Vtrux라는 이름으로도 판매되었으며, 미국, 캐나다, 멕시코 및 전 세계 여러 국가에서 이용할 수 있습니다.
My reverse light are always on
My 05 chevy 1500 has a flatbed on it and was done on amature hour. The rear end wiring wasnt working so I decided to run new wiring from the fuse box using a fuse tap all the lights work but the problem is my reverse lights are always on. My question is does the switch for the reverse lights that i assum is either on the shifter or transmission lie between the battery and fuse box or the fusebox and the lights. If it's the latter then obviously I bypassed the switch but none of the other lights are like that so I don't see that being the case
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @loganloren71558
The backup switch is between the output side of the fuse and the BCM (Body Control Module) i.e. battery → B/UP 20A fuse → backup switch → BCM → backup lights.
Here's the backup lamp wiring diagram from the service manual.
When reverse gear is selected (either AT or MT) B/UP 20A fuse supplies voltage via the operated backup switch, to the BCM. The BCM then supplies the voltage to operate the backup lamps.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Chevylodge89 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 26
전체 시간: 54
