charging problem with phone
Charging problem
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
Hi @ashishmukhi
If the phone is not charging, have you tried using a different, known working, compatible charger or charger cable and checked if it started to charge?
Has the phone been dropped or gotten wet at all?
What have you tried?
의 공유
Try using a different charging cable and plug.
Ensure the port on the phone is clear of all and any debris to the charing cable can insert properly.
Also try using a different plug on the wall to charge.
If none of these work, it would be a problem with the phone itself and then require going to a shop to be fixed.
의 공유
댓글 달기
