주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2006년 11월 북미에서 출시된 Wii는 닌텐도의 첫 가정용 게임기로, 온라인 게임과 Wii Shop Channel을 통한 게임 및 미디어 애플리케이션의 디지털 배포를 모두 지원하여 직접적인 인터넷 연결 기능을 제공했습니다.
Drive Lens not moving.
I have the rvl-001 wii and the laser lens doesn't move along the track when I put the disc in. The only answer I found scouring the Internet is bad motor, or something might be jammed with dust or dry grease. I would like help in planning what I should do to identify the problem and how to fix it, because I don't wanna spend money to fix it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
Could be many things.
It's possible that the laser died and is even unable to see the disc, hence it won't move.
It's also possible that the worm motor is broken causing the laser not to move.
And it could be the laser's clamp/bracket.
I always check the laser clamp/bracket first, if it's fine, I replace the laser. Still not working? Then I solder a new worm motor in.
You can check this guide: Nintendo Wii DVD 드라이브 렌즈 교체
Both are easy to replace (worm motor is a little soldering experience required).
I'm afraid you need to spend some money here. Glady, a laser and a worm motor is not that expensive. I would start with a new laser first, they are known to fail.
If you don't want to refurbish the drive, then just replace the whole drive and this should do the job as well. But this will be more expensive
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Adrian Proffer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 25
전체 시간: 66
