주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SEAT 차량을 위한 수리 가이드 및 수리 정보.
How to remove oil change report?
How to reset and turn off oil change report?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Hi @aymanmoham54813
What is the year and model of your Seat vehicle?
댓글 달기
답변 1개
this is what AI on chrome has to say
To reset the service or maintenance light on most modern SEAT vehicles (like the Leon, Ibiza, Ateca, or Arona), you can use either the instrument cluster's physical reset button or the digital steering wheel controls/infotainment menu. [1, 2, 3, 4]
Method 1: Using the Dashboard / Trip Button (Older & Standard Digital Clusters)
  1. Turn the ignition off.
  2. Press and hold the 0.0 / SET button (located on the instrument cluster or next to the speedometer).
  3. While holding the button, turn the ignition on (do not start the engine).
  4. Release the button when a message appears asking if you want to reset the service or oil interval.
  5. Press the button one more time briefly to confirm.
  6. Turn the ignition off; the reminder is now cleared. (Note: If both oil service and inspection are due, you may need to repeat the process for the second notification). [1, 2, 3, 4, 5]
Method 2: Using Steering Wheel Controls / Digital Menu (Newer Models like Leon MK4 / Ateca)
  1. Turn the ignition on.
  2. Use the steering wheel right-side scroll wheel or arrows to find the Trip / Vehicle Status or Settings menu on the digital dash.
  3. Scroll or press and hold the OK / Select button on a car/menu icon to open hidden choices.
  4. Navigate to the Service menu.
  5. Select Reset Oil Service or Reset Inspection, then press confirm. [1, 2, 3]
Most users on ⁠SEATCupra Forum agree that if your vehicle runs on a customized variable service schedule, a dedicated OBD diagnostic tool or VCDS cable may occasionally be required to clear deep adaptation channels. [1]
To help you get the exact steps:
  • What is the model name and model year of your SEAT?
  • Is your dashboard analog with a small screen or a fully digital cockpit?
If you share your exact model and year, I can give you the precise button sequence for your dashboard type.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ayman mohamed safwat 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 20
지난 30일: 80
전체 시간: 109
