주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus ROG Zephyrus G14 노트북을 위한 수리 안내서, 사용 설명서 및 서비스 정보입니다. Zephyrus G14는 2020년 중반에 처음 출시된 14인치 경량 게이밍 노트북입니다.
Why does my screen go to static
Sometimes when I turn my laptop on, the screen will be full static with some colored lines on the right side of the screen
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi @timmylentz
Try connecting an external monitor (TV) to the laptop's HDMI port and check if the same problem occurs on the monitor's screen. Don't forget to press the Win + p keys (both together) to choose the display options e.g. duplicate, second screen etc.
If the display on the external monitor is OK, there may be a problem with the eDP (video) cable between the motherboard and the LCD panel or in the LCD panel itself.
Switch the display back to the laptop's screen and then very slowly move the laptop lid back and forth and check if when doing this that you can either make the problem stop (if it is there) are start (if it isn't).
If you can, then it looks like the might be a problem with the cable, either a loos connection (motherboard end or LCD panel end) or it is damaged where it passes through the hinge to get from the base to the lid.
If you can't then it might be a LCD panel problem.
Here's a video that may help as it shows how to open the laptop and replace the panel, but you can also check the cable as well.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
timmy lentz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 34
전체 시간: 54
