주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo 500 시리즈 노트북을 위한 수리 안내서 및 지원 정보입니다.
It no longer works
It doesn't work, and when you try to turn it on, it stays off and doesn't turn on. It doesn't charge, and its fan doesn't turn on or give any indication that it's charging.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Hi @adambouchear
What is the full model number of the laptop as shown on the product information label on the bottom of the laptop?
댓글 달기
답변 1개
I assume you subbed the adapter or check the output voltage.
And tried running it with the adapter plugged in.
If so, there are multiple possibilities and they are all internal.
Maybe the simplist thing might be a bad pwr socket on the computer. That is a plug in replacement
Worst case is a bad MB.
It has a seperate pwr board, which is aslo a plug in replacement.
The biggest problem is figuring out which one it is, or u could just part jockey it - which is what a repair shop would do, but they gave the parts to sub.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Adam Bouc 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 44
