주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Porque no carga rapido
No carga y no sale de 1
Translation Spanish - English
Because it doesn't charge quickly. It doesn't charge and it doesn't exit from 1.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@luismiguel23018 you are not telling us if it charges at all. You are also not saying if the fast charging ever worked on this phone. It is most liklely that your K22 does not support fast charging or that you may have a bad charger and/or bad battery. Use the original charger that came with the phone an see if that will work. Let us know what you find out.
Translation
@luismiguel23018, no nos estás diciendo si se carga o no. Tampoco nos dices si la carga rápida ha funcionado alguna vez en este móvil. Lo más probable es que tu K22 no admita la carga rápida o que tengas un cargador defectuoso y/o una batería estropeada. Usa el cargador original que venía con el móvil y comprueba si así funciona. Cuéntanos qué tal te va.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Luis Miguel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 28
전체 시간: 28
