주요 콘텐츠로 건너뛰기
전문가 및 파워 유저를 위한 Apple의 노트북 라인입니다. 현재까지 맥북 프로 라인에는 13, 14, 15, 16, 17인치 제품이 있으며, 프리 유니바디(오리지널), 유니바디, 레티나 디스플레이, 터치 바, SOC(시스템 온 칩) 디자인으로 구분되는 주요 개선 버전이 있습니다.
20 질문 전체 보기
Using Mac with the cover down?
How can I prevent my mac from suspending when the cover is down, I'd like the screen to turn off, but I still want to to be able to connect via ssh, and vnc.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 4개
선택된 해법
Try setting computer sleep to 'never' in energy saver, and connect an external keyboard or mouse. Close the lid, and click mouse or keyboard key to wake unit if it goes to sleep. This should trick the MacBook Pro into "clamshell" mode. You might want to put the unit on a small riser or laptop cool pad, as it is going to get warm...
Check out this article from Apple's Knowledge Base:
http://support.apple.com/kb/HT3131
PS: You shouldn't need an external monitor connected for this to work.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
http://semaja2.net/insomniaxinfo
There is a program called InsomniaX that allows mac laptops to optionally remain awake with the lid shut. This is probably exactly what you want. It is also possible to keep the laptop awake by connecting it to an external screen, keyboard, and mouse.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
This is what I do to keep mine awake, but I still have it go to sleep after a few hours to save energy.
댓글 달기
Make sure 'Wake for Ethernet network access' is checked under the Energy Saver preferences.
However, I have never been able to get the MacBook Pro to wake from sleep with the cover closed. I suspect this is done for cooling purposes. I have had some success when a 2nd monitor is connected and turned on. Your mileage may vary.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Wake for Ethernet Administrator Access is for something called Wake On LAN, but this won't necessarily work with what Steve wants to do. It certainly won't allow him to ssh or vnc in and have his laptop auto-wake.
댓글 달기
Use energy saver display sleep also same place check wake for administrator access
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Steve Feinstein 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 4,631
