주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델: Cinema 600 모델 번호: 1068777 ASIN: B089B6VS11 UPC: 743878043822 2020년 7월 15일 출시
Subwoofer not powering on
My Klipsch Cinema 600 powers on and works fine, but the subwoofer simply died. No light, nothing. I have verified the cord and outlet, both good. I opened it up looking for a fuse and I didn't find one. Any advice? Other threads are about the main unit power supply.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi @jandsilentbob
If I've found the correct board there is a fuse on it.
It is a T3.15A 250V square plastic fuse.
Below is an image that shows where it is located. The fuse rating is printed on the board.
If it is blown, ensure that you get a T3.15A 250V fuse as a replacement and not a 3.15A 250V fuse. The T rating is important as it denotes that it is a slow blow fuse and not a normal fast acting fuse. A normal fuse having the same rating will blow immediately that the power is connected to the device due to the high inrush currents that flow whereas the slow blow fuse will hold until these currents subside. They last for about 4-8mS (milliseconds)
이미지
(click on image)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
jandsilentbob 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 51
전체 시간: 57
