주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 페이지는 Dell Vostro 2520 수리를 돕기 위한 것입니다. 배터리, 하드 드라이브, 키보드 등을 수리하는 수리 안내서가 포함되어 있습니다!
Turns on but only white screen
Laptop turns on but there is only white screen. If I connect another monitor then it works fine. I want to fix it so screen of laptops works fine and make the portability possible.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 10개
@amitkg Try to open up the laptop and reconnect the plug for the built-in screen!
Hi Theo, thank you for ur message. i did exactly as u mentioned unfortunately it doesn't work. It still 99.99% white all over the screen except 1mm upper part (that much part is good). Is there any other way to fix it without changing the screen ?
@amitstark let's see this "over the screen except 1mm upper part (that much part is good)" by posting a picture with your Question of what your screen shows. 기존 질문에 이미지 추가하기
Sorry, and I added a small video. Please check it out.
@amitstark so it does show more than just white. This actually looks like a bad LCD panel.
댓글 5개 더보기
댓글 달기
답변 1개
선택된 해법
@amitkg a white display indicates that the LCD backlight is turning on and thus receiving the proper voltage of 19V from its power rail. The issues that your laptop shows is commonly caused by a loose LVDS display cable,a damaged display connector, a damaged LCD panel, For now, check the connector and check the cable. This error looks more like a bad LCD. Use the Dell Vostro 2520 Owner's Manual which includes a service manual, to work on your computer.
For anything odd that you may see while working on it post some pictures of that so we can see what you see and help you further if needed. 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Amit K.G. 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 35
지난 7일: 39
지난 30일: 39
전체 시간: 39
