주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
병원 및 연구실을 포함한 모든 종류의 의료 실험실 장비를 위한 서비스 매뉴얼 및 지원 문서입니다.
WPA Colourwave CO7500 Colorimeter Issue
Hi! Our school laboratory owns a WPA Colourwave CO7500 Colorimeter model which was working fine last school year. Today, we turned on the colorimeter and on the upper left, a "lamp" symbol appeared and keeps flashing. When we try to take a reference, it takes too long and doesn't show 0.00 Abs. How do I fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi @michellema58643
With the device turned on, press and release the Kinetics key (see image below) and check if the flashing lamp symbol stops and that you can then perform a test.
이미지
(click on image)
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
Unfortunately even after I press and release the Kinetics key, the flashing lamp symbol still keeps showing up.
의
@michellema58643
Carefully peer into the cuvette compartment while pressing the T or R button, you may see a flash of light on the side of the compartment but if there no physical light seen then the lamp may have burnt out.
If it is determined that the lamp is the problem go to p.8 (11 of 13 pdf) in the owner manual to see how to replace the lamp.
Looking online using the part number quoted i.e. 80-3000-59 (examples) it's not cheap.
Is the device using mains or battery power only?
의
@jayeff The lamp does properly flash after I press the R button but the "lamp symbol" continuously flashes and does not give a 0.00 Abs reading. It just shows "---". The device uses a main power only.
의
@michellema58643
Can't find a service manual for the device so can only suggest that you turn it off and disconnect the power from the device and then press and hold the On/Off button for a full 30 seconds and then release it to see if this resets it.
Reconnect the power to the device, turn it on and check.
If still no good then there's a problem on the board but without a schematic etc I don't know.
의
@jayeff still didn't work :( prob an issue I won't be able to fix unless I open it up. Thank you so much your help! Really appreciate it
의
댓글 달기
답변을 추가하세요
Michelle Makaluso 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 37
전체 시간: 37
