주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung은 2024년 1월 17일 “Unpacked/언팩” 행사에서 Galaxy S24 라인을 발표했습니다. 삼성 갤럭시 S24는 2024년 주력 스마트폰의 기본 모델입니다.
Back cover is bulging out
Back cover bulging out. Is it a bad battery? Phone use is not effected.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Yes, that is almost certainly a bad battery. As batteries age, the chemical reactions that generate electricity start to break down and generate gasses instead. Those gasses cause the outer coating to swell, expanding the only direction possible, out the back of the phone. If you check your battery health, I suspect you'll find it's degraded, but regardless a swelling battery needs to be replaced immediately. This guide will tell you everything you need to know about a swollen battery.
What to do with a swollen battery - iFixit
Of course, instructions for replacing the battery would be helpful as well, and iFixit has you covered there, too.
Samsung Galaxy S24 Battery Replacement - iFixit Repair Guide
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Battery is the first thing I would suspect before anything else. It's often the culprit. After a few years batteries start to wear down.
Be VERY careful. If it is the battery, it can explode. If you open the case, do it in a well ventilated area and keep it away from anything flammable.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Brenda Stallsmith 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 16
지난 30일: 45
전체 시간: 45
