주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
정수기 수리 및 분해 안내서입니다.
Bottom loading water dispenser pump issue
I bought a brand new Hitachi bottom dispensing water cooler,
It has a sensor that indicates when the water jug is empty.
I have an issue that recently occurred which is that when then the water jug is empty, it seems to take in air along with the last drops of water and keeps the pump sucking air instead of turning off as it's supposed to.
It has happened two times and I have no clue how to troubleshoot it nor have I found any resources.
Update (10/03/26)
Update:
I removed all hoses, the bare pump still pumped dry so it has nothing to do with the hose system. I also completely emptied it of any water even from the drain pipe
The pump itself works fine
I also checked the floats and they seem to be in good order
If anyone has any idea on what it possibly is please tell me.
This is only the 4th cycle or jug and the first two were fine.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi @aliclay
What is the model number of the water dispenser?
의 공유
의 공유
댓글 달기
답변 1개
가장 유용한 답변
Hi @aliclay
As you stated, no resources online.
If a user manual came with the dispenser, check if there's a troubleshooting section or perhaps the cleaning section in the manual to see if it mentions the problem or if the product has to be cleaned occasionally especially if it mentions cleaning a sensor window or suchlike.
Since it is brand new check the warranty information that is in the user manual or came with it as to how to contact the Hitachi customer service centre (or authorized repairer) in your location and ask them for a manufacturer's warranty repair or replacement.
Try not to disassemble the dispenser more than what is shown in the user guide so that you don't void the warranty.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Ali Clay 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 28
전체 시간: 52
