주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toyota Camry XV20 시리즈는 Toyota의 6세대 Camry 세단입니다.
Code P0758 Camry 1998 V6
Hi everyone! I have a 1998 Toyota Camry V6 with Automatic transmission. I’ve got a Check Engine light with code P0758 wich means Solenoid B Electrical. The car is originally from California and drove 41 000 miles there before it got imported to Norway in 2007. It has only drove 42 000 miles since then here in Norway, so I find it difficult to see a problem with the wirings. Does anyone have experienced kind of the same problem and help me out?
Camry Owner.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @vebjoernbek4505
The car is approx. 28 years old so a wiring problem is not out of the question. The wiring could fail for any number of reasons e.g. corrosion, wiring fatigue etc.
Here's the P0758 diagnosis and repair procedure from the service manual, that may help.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Hi! I did som research and found out that the S2 terminal in the transaxle connector is OL, and the manual then says «replace the transaxle sub-harness as needed». I can’t find the part number for this specific part (sub-harness). Can you help me out? I’m starting to realize that this sounds expensive if I have to use specialists…
의 공유
@vebbe11
Try this website and see if you can find it.
의 공유
댓글 달기
답변을 추가하세요
Vebjørn 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 41
전체 시간: 60
