주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple의 2021년 최고급 스마트폰. 9월 24일에 출시된 iPhone 13 Pro Max는 6.7형 ProMotion OLED 디스플레이, 새로운 트리플 후면 카메라 시스템, 5G 연결성을 자랑합니다. iPhone 12 Pro Max의 후속 제품입니다.
Cellular front end diagnostic
How do you guys go about diagnosing Cellular front end issues on iPhone? I’ve replaced the charging flex on two iPhones recently and they end up failing the Apple diagnostics after. Cellular appears to be fine and working. The replacement flex is OEM pull. It appears to be working correctly as it all passed the diagnostic except for the Cellular test. Is there anything specific I should look for? I cleaned and checked all the grounding contact points on the screen/frame and the pins themselves and they looked fine. The only repair this 13 Pro Max had was a charging port replacement. I only removed the lower components needed to do the replacement so Im not really sure what went wrong.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Molded within the case are the antennas which are accessed by the cellular front-end logic via screws and bus bars. Make sure you have a good electrical connection between the Antenna point and the logic board. Any corrosion, tarnish or physical damage can prevent good connection to your cellular provider.
To see the signal strength I just use the codes as listed here All iPhone Secret Codes
*#3001#12345#*
Use a second phone accessing the same carriers network at the same location to gage if your connection is good.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
CAB 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 32
전체 시간: 52
