주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1989, EMC 3358. 기존 디자인을 새롭게 개선한 모델로, 프로세서 옵션이 업데이트되었으며 키보드 소재가 변경되었습니다. 실버 및 스페이스 그레이 색상으로 제공됩니다. 2019년 5월 출시.
Flickering Area On The Screen
I am not 100% sure the model as it is from a friend back in the UK, Has a Touchbar and I think it is a 2019 13" Pro, anyway, the lower left corner on the screen was flickering (Together with a vertical line down the center). yes we know it will need a new screen, but what would cause the flickering on an area at the bottom left corner 4-5com, a dirty connection? The rest of the screen is OK apart from the vertical line as seen in the video. The unit since the video was taken does not display anything at all at any angle or whatever, totally blank. I'm curious what causes the small flickering area. @danj for the info.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
If you look along the bottom you can see a grey horizontal bar besides the vertical bar. This horizontal bar is a timing issue of the signal that is drawing the image.
The placement of the T-CON board which creates the signal is located at a hot location between the two heatsink radiators and there fans. So heavy processing loads as well as dust & debris clogging the cooling system tend to cook the T-CON causing signal drift.
Cleaning the fan blades and the heatsink radiator's fins can reduce the heat to stagnate and speeding up the fan's RPM can expel it. Then lastly making sure the vents aren't blocked. Sadly, often times replacing old the display is required to fix it ones it gets bad as the T-CON can't be replaced on its own.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you @danj I had a hunch it was to do with it never having a fresh thermal pasting and an internal cleanup..... I have forwarded the info to my friend and he will get someone to give it some attention and fingers crossed he can get a little more life out of it, enough time to make a back-up of his data etc.
의 공유
댓글 달기
답변을 추가하세요
livfe 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 19
지난 7일: 19
지난 30일: 19
전체 시간: 19
