주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Phone fully died after unplugging
Hey there i replaced my phone lcd lately and it was working super fine until I decided to unplug the charger and plug it in somewhere else
I unplugged it and the screen went full black and when I connected it to the charger again nothing showed up even when I held the power button nothing happend it just got a little warm
I tested the ampers and it's taking 0.6AMPS from the charger
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @parhammirzaie
Start off by replacing the battery.
If the phone turned off when the charger was disconnected and coupled with the fact that it won't turn on again when the charger is reconnected it's a reasonable assumption that the battery has failed. The charger can't do both i.e. turn on and run the phone and charge the battery at the same time if the battery has failed.
You could try leaving the phone on charge for 2-3 hours to see if the battery starts to charge again and then see if it turns on with the charger connected. If it does start to charge I suggest that you let it fully charge before turning on the phone.
If you decide to replace the battery, here's a video that shows what to do.
Search online for EB-BA310ABE to find battery suppliers that suit you best.
이 답변이 도움이 되었나요?
점수 1
댓글 9개:
Thanks for helping I'll try to charge it for 2-3 hours first
의 공유
It didn't boot
의 공유
@parhammirzaie
Did the battery start charging and if so, did you let the battery fully charge, you didn't say?
If it didn't start charging or fully charge try replacing the battery and then check if it works.
의 공유
@jayeff It goes warm - cool - warm - cool
And still nothing showed up and I think the battery is too under voltage
의 공유
@parhammirzaie
Yep, replace the battery
의 공유
댓글 4개 더보기
댓글 달기
답변을 추가하세요
parham mirzaie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 61
지난 30일: 61
전체 시간: 61
