How to replace the internal clock battery
How to replace the internal clock battery ?
좋은 질문입니까?
좋은 질문입니까?
BTW, you might want to know before you open the case that the battery you are replacing is labeled "ML1220/2E2E0X", which is a small watch-style cmos button battery soldered to a wire pigtail, so it's ready to plug in.
They can be found on ebay or Amazon; if you're paying more than $5 including shipping, you're being ripped off.
Another option is un-solder the original, find a generic ML1220 battery, and then solder the old pigtail connector to it, using shrink-wrap tubing to seal things back up.
[This battery is probably identical to the very common CR1220, both being 3V lithium button batteries. Dunno. Switch to a different model if you don't mind the uncertainty and risk.]
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 5
지난 30일: 48
전체 시간: 10,700
