주요 콘텐츠로 건너뛰기
Acer Aspire E5-471-5456 USB Port Replacement
Justin Saeidian
Justin Saeidian2 다른 기여자
최종 수정일 January 1, 2018
10 분
조정
The USB port is one of the most commonly used ports on your computer. Having a functional USB port is almost required to allow your computer to interface with other devices.The USB port may have a buildup of dust that can cause issues with connection to the port.
필요한 것
도구
  1. Acer Aspire E5-471-5456 USB Port Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Acer Aspire E5-471-5456 USB Port Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Carefully place the closed computer on a flat surface, with it oriented screen down.
    • Now you need to use the Phillips #0 Screwdriver to remove all 17 of the M2.5X8 mm screws. Use the red circles on the diagram to help you locate these screws.
  2. Acer Aspire E5-471-5456 USB Port Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire E5-471-5456 USB Port Replacement: 2 단계, 이미지 2개 중 2개
    • Use an opening tool to gently pry open the case.
    • Take extreme care when removing the case to not get the case stuck on any of the ports. Make sure that to evenly open the case and not pry one side open before the other to avoid damage.
    • Slowly peel the cover off and make sure there are no wires or clips still connecting the two pieces together. These pieces are extremely fragile so it is vital to take your time and only use light pressure.
  3. Acer Aspire E5-471-5456 USB Port Replacement: 3 단계, 이미지 1개 중 1개
    • Place cover and screws aside and you are now free to access the different components of this laptop.
    Acer Aspire 5749 (never opened)-must clean or buy new!
    *Back cover will not release at phone jack corner;
    hours & hours of trying every tip I can find- It won’t come off or lift enough to disconnect any wires…Desperate & fingers are shredded!
    What’s the trick???
    raineyday1 - 답글
  4. Acer Aspire E5-471-5456 USB Port Replacement, USB Port: 4 단계, 이미지 2개 중 1개 Acer Aspire E5-471-5456 USB Port Replacement, USB Port: 4 단계, 이미지 2개 중 2개
    • Locate the two USB ports in the bottom corner of the laptop.
    • Use a screwdriver to take out the M2X3 mm screw located in the orange circle. For an easier reassembly, take note that the USB port has a white arrow that indicates which  orange hole the screw should be returned to.
  5. Acer Aspire E5-471-5456 USB Port Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire E5-471-5456 USB Port Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the cable (look for the one with a blue tag reading "USB") very carefully as it is fragile by using the opening tool.
  6. Acer Aspire E5-471-5456 USB Port Replacement: 6 단계, 이미지 1개 중 1개
    • The USB ports should now be able to be removed from the laptop, carefully.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Justin Saeidian
회원 가입일: 09/26/17
300 평판
안내서 2개를 작성함
Cal Poly, Team S6-G4, Banghart Fall 2017 Cal Poly, Team S6-G4, Banghart Fall 2017 회원
CPSU-BANGHART-F17S6G4
5 회원들
안내서 6개를 작성함
댓글 한 개
where can i purchase the port
Jermian Francis - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 10
전체 시간: 2,097
