주요 콘텐츠로 건너뛰기
Acer Aspire R7 Wi-Fi Card Replacement
Andrew Rodiek
Andrew Rodiek4 다른 기여자
최종 수정일 May 17, 2022
15 - 25 분
조정
학생이 작성 중
In this guide, you will learn how to replace the Wi-Fi card on the Acer Inspire R7 laptop (‎R7-371T-78GX).
A Wi-Fi card is used to receive wireless signals from your wireless network. Over time the Wi-Fi card can fail or be upgraded for a stronger card. Review the iFixit page on the Acer Aspire R7 for more details on Wi-Fi card issues.
When starting this project, make sure to power off your laptop and unplug from the power adapter. Overlooking this detail can cause damage to hardware.
필요한 것
도구
더보기...
  1. Acer Aspire R7 Wi-Fi Card Replacement, Cover: 1 단계, 이미지 1개 중 1개
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Wi-Fi Card Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire R7 Wi-Fi Card Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire R7 Wi-Fi Card Replacement: 2 단계, 이미지 3개 중 3개
    • Remove six 6mm T7 screws.
    • Remove four 4mm T7 screws.
    • Remove two 10mm T7 screws
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining two10mm T7 screws.
  3. Acer Aspire R7 Wi-Fi Card Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 2개 중 1개 Acer Aspire R7 Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 2개 중 2개
    • Locate the WiFi Card antenna wires
    • Remove both antenna wires from the WiFi card by prying upwards with the spudger tool
  5. Acer Aspire R7 Wi-Fi Card Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the (1) 3.5mm #00 Phillips retaining screw
    • Once the screw is removed, the spring loaded hinge will tilt the WiFi card up
  6. Acer Aspire R7 Wi-Fi Card Replacement: 6 단계, 이미지 1개 중 1개
    • With the retaining screw removed, pull the WiFi card out of the socket
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Andrew Rodiek
회원 가입일: 01/13/15
601 평판
안내서 4개를 작성함
USF Tampa, Team 3-4, Hickman Winter 2015 USF Tampa, Team 3-4, Hickman Winter 2015 회원
USFT-HICKMAN-W15S3G4
4 회원들
안내서 7개를 작성함
댓글 2개
The factory wi fi card is so weak. Is there a better wi fi card to buy and put in? 952-454-1659 Thank you
John - 답글
This answer might be useful for others who still want to update their Wifi card in their R7-572.
I just replaced the original Broadcom BCM943228HMB on my R7-572 with an Intel 7260HMW CN: 08TF1D (Standard half-height mini PCI-e interface card ). I found it on ebay:https://www.ebay.ca/itm/4-0-Wireless-Min... (19 USD as of October 2018)
After the card is installed, run Intel Driver & Support Assistant and my driver where updated to the latest ones (for both the AC 7260 and the Bluetooth adapter). http://www.intel.com/content/www/us/en/s...
I am using Windows 8.1 on this laptop.
HTH
Michael Cantinotti - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 29
전체 시간: 4,142
