주요 콘텐츠로 건너뛰기
Acer Chromebook 14 CB3-431-C3WS Battery Replacement
Samantha Postma
Samantha Postma2 다른 기여자
최종 수정일 March 1, 2021
10 분
쉬움
If your Acer Chromebook 14 CB3-431-C3WS does not turn on when the power button is pushed, doesn’t remain charged or usable unless connected to an external power source you may need to replace the battery.
Try following this troubleshooting guide before attempting to replace the battery to see if you can find an easier solution.
Before beginning, make sure that your laptop is completely turned off, and disconnected from any external power sources.
필요한 것
부품
도구
더보기...
  1. Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook 14 CB3-431-C3WS Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: 5 단계, 이미지 3개 중 1개 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: 5 단계, 이미지 3개 중 2개 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: 5 단계, 이미지 3개 중 3개
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: 6 단계, 이미지 2개 중 1개 Acer Chromebook 14 CB3-431-C3WS Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
    Does anyone know the part number for a battery?
    David York - 답글
  7. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the battery out gently.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Samantha Postma
회원 가입일: 10/15/19
1,238 평판
안내서 6개를 작성함
댓글 3개
Bonjour vous vendez les batteries CB3-431
mercier-nicolas - 답글
Vous vendez les batteries CB3-431
Instructions were great. Battery installation complete! I was very glad to find step by step instructions instead of a video. The Chromebook powered up successfully. Now waiting for it to charge. Thank you!
Sherry Chase - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 23
전체 시간: 5,690
