주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-532-C47C Screen Replacement
Sadie Brown
Sadie Brown2 다른 기여자
최종 수정일 May 30, 2022
25 - 45 분
조정
커뮤니티-기여 안내서
더 나은 이미지가 필요함
더 많은 이미지가 필요함
Use this guide to replace the Acer Chromebook 15 CB3-532-C47C screen.
The computer screen is responsible for displaying all of the visual output contained in the laptop. A broken or malfunctioning screen can show varying symptoms including signs of damage such as cracks, inconsistent resolution or coloration, black spots, screen flickering, or complete loss of image display. Screen swelling caused by physical damage or temperature fluctuations can also be visible in some faulty screens.
Absence of any image on the screen could be caused by problems with other laptop components, so review the troubleshooting page to rule out other possible causes.
Make sure that you power off and unplug your computer before beginning.
필요한 것
도구
  1. Acer Chromebook CB3-532-C47C Screen Replacement, Front Bezel: 1 단계, 이미지 2개 중 1개 Acer Chromebook CB3-532-C47C Screen Replacement, Front Bezel: 1 단계, 이미지 2개 중 2개
    • Power off your computer before beginning
    • Open the laptop and pry off the bezel on the front of the screen using the opening pick or plastic opening tool.
  2. Acer Chromebook CB3-532-C47C Screen Replacement, Screen: 2 단계, 이미지 3개 중 1개 Acer Chromebook CB3-532-C47C Screen Replacement, Screen: 2 단계, 이미지 3개 중 2개 Acer Chromebook CB3-532-C47C Screen Replacement, Screen: 2 단계, 이미지 3개 중 3개
    • Using the Phillips #1 screwdriver, remove four silver 3 mm screws on the corners of the screen.
  3. Acer Chromebook CB3-532-C47C Screen Replacement: 3 단계, 이미지 3개 중 1개 Acer Chromebook CB3-532-C47C Screen Replacement: 3 단계, 이미지 3개 중 2개 Acer Chromebook CB3-532-C47C Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Peel off the tape securing the screen cable and pull the cable off the screen.
    • Remove the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sadie Brown
회원 가입일: 10/25/21
967 평판
안내서 7개를 작성함
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S3G2
3 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 28
전체 시간: 355
