주요 콘텐츠로 건너뛰기
Acer TravelMate P653-V-6882 DC Input Replacement
Daniel Popovic
Daniel Popovic다른 한 명의 기여자
최종 수정일 June 9, 2020
25 분
조정
If the power indicator is not lit regardless of the Acer TravelMate P653-V-6882 being plugged in (with a working power adapter) or not, then the DC input may be faulty. In order to be able to charge your laptop correctly again, follow this guide on how to replace the DC input port.
It is important to know that you will have to remove the TravelMate’s mainboard.
필요한 것
도구
더보기...
  1. Acer TravelMate P653-V-6882 DC Input Replacement, Battery Pack: 1 단계, 이미지 2개 중 1개 Acer TravelMate P653-V-6882 DC Input Replacement, Battery Pack: 1 단계, 이미지 2개 중 2개
    • Turn the computer over so the base is facing up.
    • Slide the battery lock to unlock position.
  2. Acer TravelMate P653-V-6882 DC Input Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery release latch to the right.
    • The battery pack will pop out.
  3. Acer TravelMate P653-V-6882 DC Input Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the battery up.
    • Pull out the battery.
  4. Acer TravelMate P653-V-6882 DC Input Replacement, ODD Module: 4 단계, 이미지 1개 중 1개
    • Slide the ODD module latch down.
    • The ODD module will pop out.
  5. Acer TravelMate P653-V-6882 DC Input Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the ODD module.
  6. Acer TravelMate P653-V-6882 DC Input Replacement, Base Door: 6 단계, 이미지 1개 중 1개
    • Remove the five 7mm Phillips #1 screws.
  7. Acer TravelMate P653-V-6882 DC Input Replacement: 7 단계, 이미지 1개 중 1개
    • Use the opening tool to separate base door from the bottom of the laptop.
    • Be careful not to bend or crack the plastic back cover.
  8. Acer TravelMate P653-V-6882 DC Input Replacement: 8 단계, 이미지 2개 중 1개 Acer TravelMate P653-V-6882 DC Input Replacement: 8 단계, 이미지 2개 중 2개
    • Gently pry open the base door by pushing up.
    • Pull out the base door.
  9. Acer TravelMate P653-V-6882 DC Input Replacement, Keyboard: 9 단계, 이미지 1개 중 1개
    • Remove the two 7mm Phillips #1 screws.
  10. Acer TravelMate P653-V-6882 DC Input Replacement: 10 단계, 이미지 1개 중 1개
    • Flip the laptop so that the underside is now facing the bottom.
    • Open the LCD panel.
    • Use the flat end of a spudger to push in the six latches.
    • Be careful not to bend or crack the keyboard.
  11. Acer TravelMate P653-V-6882 DC Input Replacement: 11 단계, 이미지 1개 중 1개
    • When the latches are pushed in, the keyboard will pop out.
    • Gently pry up the keyboard.
  12. Acer TravelMate P653-V-6882 DC Input Replacement: 12 단계, 이미지 1개 중 1개
    • Slide the keyboard forward to access the keyboard cable.
    • Flip the connector latch up to open it.
    • Pull out the keyboard cable gently.
    • Be careful not to damage the connector.
  13. Acer TravelMate P653-V-6882 DC Input Replacement, Mainboard: 13 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 DC Input Replacement, Mainboard: 13 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 DC Input Replacement, Mainboard: 13 단계, 이미지 3개 중 3개
    • Turn the computer over, open the LCD panel, and find the smart card cable connector.
    • Open the smart card cable connector latch.
    • Disconnect the cable.
  14. Acer TravelMate P653-V-6882 DC Input Replacement: 14 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 DC Input Replacement: 14 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 DC Input Replacement: 14 단계, 이미지 3개 중 3개
    • Find the power button launch board cable connector.
    • Open the power button launch board cable connector latch.
  15. Acer TravelMate P653-V-6882 DC Input Replacement: 15 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 DC Input Replacement: 15 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 DC Input Replacement: 15 단계, 이미지 3개 중 3개
    • Find the touchpad and fingerprint board cable connector.
    • Open the touchpad and fingerprint board cable connector’s latches.
    • Disconnect the cables.
  16. Acer TravelMate P653-V-6882 DC Input Replacement: 16 단계, 이미지 1개 중 1개
    • Using the #1 Phillips screwdriver, remove the two screws.
  17. Acer TravelMate P653-V-6882 DC Input Replacement: 17 단계, 이미지 1개 중 1개
    • Flip the laptop over so that the underside is facing up.
    • Remove the twelve 7mm Phillips #1 screws.
    • Remove the five 3mm Phillips #1 screws.
    • Disconnect the cables connecting to the WLAN module.
  18. Acer TravelMate P653-V-6882 DC Input Replacement: 18 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 DC Input Replacement: 18 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 DC Input Replacement: 18 단계, 이미지 3개 중 3개
    • Locate the small gaps between the upper cover and lower case on the left and right side of the laptop.
    • Insert the opening tool into each gap to separate the one from the other.
    • Once the upper cover is separated, lift it from the lower case.
    • Be careful not to damage the upper and lower case while removing.
  19. Acer TravelMate P653-V-6882 DC Input Replacement: 19 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 DC Input Replacement: 19 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 DC Input Replacement: 19 단계, 이미지 3개 중 3개
    • Detach the transparent tape securing the LCD cable.
    • Disconnect the LCD cable from the mainboard.
    • Be careful not to damage the LCD cable connector.
  20. Acer TravelMate P653-V-6882 DC Input Replacement: 20 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 DC Input Replacement: 20 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 DC Input Replacement: 20 단계, 이미지 3개 중 3개
    • Detach the black tape covering the microphone cable.
    • Disconnect the microphone cable from the mainboard.
  21. Acer TravelMate P653-V-6882 DC Input Replacement: 21 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 DC Input Replacement: 21 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 DC Input Replacement: 21 단계, 이미지 3개 중 3개
    • Open the USB board cable's connector latches.
    • Be careful not to damage the connectors.
  22. Acer TravelMate P653-V-6882 DC Input Replacement: 22 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 DC Input Replacement: 22 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 DC Input Replacement: 22 단계, 이미지 3개 중 3개
    • Disconnect the left speaker cable from the mainboard.
  23. Acer TravelMate P653-V-6882 DC Input Replacement: 23 단계, 이미지 1개 중 1개
    • Remove the one 7mm Phillips #1 screw.
  24. Acer TravelMate P653-V-6882 DC Input Replacement: 24 단계, 이미지 2개 중 1개 Acer TravelMate P653-V-6882 DC Input Replacement: 24 단계, 이미지 2개 중 2개
    • Lift the mainboard at an angle and gently turn it on its side.
    • Disconnect the LAN cable from the mainboard.
  25. Acer TravelMate P653-V-6882 DC Input Replacement, DC Input: 25 단계, 이미지 1개 중 1개
    • Disconnect the DC input cable from the mainboard.
결론
작성자
1다른 기여자 명과 함께
Daniel Popovic
회원 가입일: 01/13/20
991 평판
안내서 7개를 작성함
York University, Team S1-G6, Woodhouse Winter 2020 York University, Team S1-G6, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G6
3 회원들
안내서 9개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 313
