주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Analogue Pocket Battery Replacement
필요한 것
  1. Analogue Pocket Battery Replacement, Prepare your device for disassembly: 1 단계, 이미지 3개 중 1개 Analogue Pocket Battery Replacement, Prepare your device for disassembly: 1 단계, 이미지 3개 중 2개 Analogue Pocket Battery Replacement, Prepare your device for disassembly: 1 단계, 이미지 3개 중 3개
    • Unplug all cables and fully power off your device.
    • Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
    댓글 쓰기
  2. Analogue Pocket Battery Replacement, Unfasten the battery shell: 2 단계, 이미지 2개 중 1개 Analogue Pocket Battery Replacement, Unfasten the battery shell: 2 단계, 이미지 2개 중 2개
    • Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
    댓글 쓰기
  3. Analogue Pocket Battery Replacement, Remove the battery shell: 3 단계, 이미지 3개 중 1개 Analogue Pocket Battery Replacement, Remove the battery shell: 3 단계, 이미지 3개 중 2개 Analogue Pocket Battery Replacement, Remove the battery shell: 3 단계, 이미지 3개 중 3개
    댓글 쓰기
  4. Analogue Pocket Battery Replacement, Disconnect the battery: 4 단계, 이미지 2개 중 1개 Analogue Pocket Battery Replacement, Disconnect the battery: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use blunt nose tweezers to pull the battery connector out of its socket on the bottom right corner of your device.
    • If you're having trouble, try rocking the connector side-to-side to help loosen it.
    • During reassembly, use the flat end of a spudger to push down on the edges of the connector until it's secure in the socket.
    댓글 쓰기
  5. Analogue Pocket Battery Replacement, Remove the battery: 5 단계, 이미지 3개 중 1개 Analogue Pocket Battery Replacement, Remove the battery: 5 단계, 이미지 3개 중 2개 Analogue Pocket Battery Replacement, Remove the battery: 5 단계, 이미지 3개 중 3개
    • Lift one of the battery's short edges until the clips release.
    • Remove the battery.
    • During reassembly, push the battery into its recess until the clips engage.
    댓글 쓰기
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
194,962 평판
안내서 1,243개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 26,593개를 작성함
2가이드 댓글
So where does one find the replacement battery? Can't find one anywhere?!?
Jonathan Smookler - 답글 공유
Great guide, but there are no replacement batteries for sale
Bart Mlotkowski - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 75
지난 30일: 308
전체 시간: 7,138
