주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Anker 2.4G Wireless Mouse Left and Right Button Replacement
필요한 것
    1. Anker 2.4G Wireless Mouse Left and Right Button Replacement, Left and Right Buttons: 1 단계, 이미지 1개 중 1개
      • Peel off the stickers. This will reveal the location of four screws.
      댓글 쓰기
    2. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the four screws using a Phillips #0 screwdriver.
      댓글 쓰기
    3. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 3 단계, 이미지 2개 중 1개 Anker 2.4G Wireless Mouse Left and Right Button Replacement: 3 단계, 이미지 2개 중 2개
      • Use a spudger to pry apart the upper and lower housing of the mouse.
      댓글 쓰기
    4. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 4 단계, 이미지 1개 중 1개
      • Pull the wires from the white crimping headers to disconnect them. This separates the top housing from the bottom housing.
      • Pull as far up on the wires as possible. Be careful not to rip the wires by applying too much force.
      댓글 쓰기
    5. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the scroll wheel from the mother board by pulling it to the left.
      • This may take some force to remove. Make sure to pull the scroll wheel parallel to the board, not perpendicularly.
      댓글 쓰기
    6. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 6 단계, 이미지 1개 중 1개
      • Pull the mother board gently away from the plastic housing.
      댓글 쓰기
    7. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 7 단계, 이미지 2개 중 1개 Anker 2.4G Wireless Mouse Left and Right Button Replacement: 7 단계, 이미지 2개 중 2개
      • Desolder the components and re-solder the replacements in order to repair the left and right buttons.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Vincent Lee
회원 가입일: 01/23/14
365 평판
안내서 3개를 작성함
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 회원
CPSU-MANESS-W14S1G39
4 회원들
안내서 16개를 작성함
2가이드 댓글
i bought the same mouse on amazon the same day i got it stopped working and anker was out of stock so i couldn't get another one directly from them, plus i really like it i opened up the mouse using your step by step and found the issue.
jacques gates - 답글 공유
where can these replacement button switches be purchased….thanks ric
Ric Scambler - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 32
전체 시간: 5,269
