소개
Use this guide to replace a worn-out or dead battery in your Apple Watch Series Ultra.
There is a significant chance that you may break the OLED panel during this procedure. Be sure to apply plenty of heat and be extremely careful during the prying stage.
You’ll need replacement adhesive to reattach the screen when reassembling the device. Your device will function normally, but will most likely lose its IP6X (Ingress Protection) rating.
필요한 것
Heat an iOpener and apply it to the screen for two minutes to loosen the adhesive underneath.
Place the tip of an iFlex along the edge opposite the Digital Crown and position it in the seam between the screen and the frame.
Press the iFlex firmly straight down into the gap.
Insert an opening pick in the gap you created between the screen and the frame.
Remove the iFlex.
Slide the opening pick around the top left corner and along the top edge of the watch to slice the screen adhesive.
Insert the opening pick between the screen and frame at the opposite edge of the Digital Crown.
Pry up the screen until you can get a good grip with your fingers.
Lift the screen up and carefully pull it towards the Digital Crown.
Swing the screen open to an upward position.
Use a Y000 driver to remove the two 2.3 mm‑long screws securing the metal connector bracket at the bottom edge of the watch.
Use the point of a spudger to pry up the battery connector towards the battery.
Use a Y000 driver to remove the 2.9 mm‑long screw securing the battery.
Use a Y000 driver to unscrew the 2.1 mm‑long screw that's sandwiched between the metal bracket.
Use a pair of tweezers to remove the bracket with the screw sandwiched between it.
Use an opening pick to lift up the battery.
Remove the battery from the case.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your Apple Watch Ultra, follow these instructions in reverse order. Apply a little bit of high isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the edges of the watch case and the screen before installing new adhesive.
For optimal performance, calibrate your newly installed battery after completing this guide.
다른 4명이 해당 안내서를 완성하였습니다.
