주요 콘텐츠로 건너뛰기
Astro A40 TR Internal wiring components Replacement
Mike
Mike2 다른 기여자
최종 수정일 May 31, 2022
15 - 20 분
어려움
더 나은 소개글
필요한 것
도구
더보기...
  1. Astro A40 TR Internal wiring components Replacement, Speakers: 1 단계, 이미지 2개 중 1개 Astro A40 TR Internal wiring components Replacement, Speakers: 1 단계, 이미지 2개 중 2개
    • To access the speakers you need to disassemble the earpiece. First remove the foam ear piece by simply pinching the padding and pulling lightly until the magnets disengage.
  2. Astro A40 TR Internal wiring components Replacement: 2 단계, 이미지 3개 중 1개 Astro A40 TR Internal wiring components Replacement: 2 단계, 이미지 3개 중 2개 Astro A40 TR Internal wiring components Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the dust cover located on the speaker. Use the corner of the spudger to peel underneath the cover until you can lift it by hand. The cover is held onto the device with adhesive and should be removed slowly.
  3. Astro A40 TR Internal wiring components Replacement: 3 단계, 이미지 2개 중 1개 Astro A40 TR Internal wiring components Replacement: 3 단계, 이미지 2개 중 2개
    • Take off the front cover by removing the four screws located in a square formation on the surface of the device. Use the J00 Philips driver listed in the device page.
  4. Astro A40 TR Internal wiring components Replacement: 4 단계, 이미지 2개 중 1개 Astro A40 TR Internal wiring components Replacement: 4 단계, 이미지 2개 중 2개
    • Locate the three small screws under the speaker. Use the J00 Philips Driver to remove them.
  5. Astro A40 TR Internal wiring components Replacement: 5 단계, 이미지 1개 중 1개
    • If your issue is asking for the complete replacement of the speaker or the motherboard, un-solder the old components and replace with new speaker by re-soldering.
    • Check out this useful guide on how to solder and desolder connections if soldering is new to you.
  6. Astro A40 TR Internal wiring components Replacement, Internal wiring components: 6 단계, 이미지 1개 중 1개
    • Untie the disconnected wiring harness.
  7. Astro A40 TR Internal wiring components Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the black wire out of the hole in the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mike
회원 가입일: 10/20/16
448 평판
안내서 3개를 작성함
UMass Dartmouth, Team 6-5, Martin Fall 2016 UMass Dartmouth, Team 6-5, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G5
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 65
전체 시간: 8,019
