주요 콘텐츠로 건너뛰기
Asus MeMO Pad 7 (ME572C) Battery Replacement
Tyler Tripp
Tyler Tripp5 다른 기여자
최종 수정일 May 22, 2024
10 - 15 분
쉬움
This guide will show you how to replace a battery for a Asus MeMO Pad 7. The battery replacement is a simple procedure. If the battery is dead, the replacement could help your tablet to turn on.
필요한 것
도구
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  1. Asus MeMO Pad 7 (ME572C) Battery Replacement, Rear Panel: 1 단계, 이미지 2개 중 1개 Asus MeMO Pad 7 (ME572C) Battery Replacement, Rear Panel: 1 단계, 이미지 2개 중 2개
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
    • The panel will be glued on and requires pressure to open.
  2. Asus MeMO Pad 7 (ME572C) Battery Replacement: 2 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 (ME572C) Battery Replacement: 2 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 (ME572C) Battery Replacement: 2 단계, 이미지 3개 중 3개
    • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
    • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
    • Carefully run the plastic opening tool along all the edges of the tablet.
  3. Asus MeMO Pad 7 (ME572C) Battery Replacement: 3 단계, 이미지 1개 중 1개
    • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
  4. Asus MeMO Pad 7 (ME572C) Battery Replacement, Battery: 4 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 (ME572C) Battery Replacement, Battery: 4 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 (ME572C) Battery Replacement, Battery: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Disconnect the ZIF connectors to release the data cables holding the battery in. Use tweezers to do this.
    • You can also use your hand to remove ZIF connectors.
    • ZIF connectors are delicate so be careful when you are removing them.
  5. Asus MeMO Pad 7 (ME572C) Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Find the place where the battery connector is. Disconnect the battery connectors by carefully pulling up on them using a spudger or plastic opening tool.
  6. Asus MeMO Pad 7 (ME572C) Battery Replacement: 6 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 (ME572C) Battery Replacement: 6 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 (ME572C) Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Using a plastic opening tool carefully pry the battery loose. The battery is glued to the pad; slight pressure will be needed to remove the battery.
    • The casing of the battery is soft and can easily tear. Tearing can lead to the chemicals in the battery to leak out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Tyler Tripp
회원 가입일: 08/26/15
395 평판
안내서 2개를 작성함
USF Tampa, Team 14-23, Meier Fall 2015 USF Tampa, Team 14-23, Meier Fall 2015 회원
USFT-MEIER-F15S14G23
4 회원들
안내서 14개를 작성함
댓글 한 개
But whats the secret to cleaning off the glue and resealing it?
Pico Herbie - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 54
전체 시간: 36,516
