Asus X553MA-BPD07051 Hard Drive Replacement
If you are having issues with windows giving you error messages for your hard drive, or have identified that there are bad sectors in the hard drive, this is an indication that the hard drive should be replaced on the laptop. Once you have identified that the hard drive is indeed the issue, replace it using this guide. For more troubleshooting advice, click here. Ensure that before removing the hard drive, the laptop is powered off, and the battery has been removed.
필요한 것
수리 키트
이 키트는 이 안내서를 완료하는데 필요한 모든 부품과 도구를 포함하고 있습니다.
부품
도구
더보기...
동영상 개요
Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
Use a Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws that are securing the hard drive.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
ryuuganhp, thanks for your comment. Very important and helpful.
