주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Beats Studio 2 Wireless Bluetooth Board Replacement
필요한 것
    1. Beats Studio 2 Wireless Bluetooth Board Replacement, Ear Cushion: 1 단계, 이미지 2개 중 1개 Beats Studio 2 Wireless Bluetooth Board Replacement, Ear Cushion: 1 단계, 이미지 2개 중 2개
      • Insert a spudger between the plastic part of the left headphone and the ear cushion.
      • Work the spudger around the periphery of the base of the cushion and gently pry it off the head phone.
      댓글 쓰기
    2. Beats Studio 2 Wireless Bluetooth Board Replacement: 2 단계, 이미지 3개 중 1개 Beats Studio 2 Wireless Bluetooth Board Replacement: 2 단계, 이미지 3개 중 2개 Beats Studio 2 Wireless Bluetooth Board Replacement: 2 단계, 이미지 3개 중 3개
      • Pull the rest of the cushion away from the adhesive with your hands.
      댓글 쓰기
    1. Beats Studio 2 Wireless Bluetooth Board Replacement, Speaker: 3 단계, 이미지 2개 중 1개 Beats Studio 2 Wireless Bluetooth Board Replacement, Speaker: 3 단계, 이미지 2개 중 2개
      • Using the Phillips #00 screwdriver, remove the screws holding the speaker in place.
      • If the speaker is on the side with the charging port be sure to keep the two screws holding the charging port separate.
      댓글 쓰기
    2. Beats Studio 2 Wireless Bluetooth Board Replacement: 4 단계, 이미지 1개 중 1개
      • Gently separate the speaker from the headphones.
      • Don't pull or yank the speaker from the headphones. They are connected together by wires that might be damaged.
      댓글 쓰기
    3. Beats Studio 2 Wireless Bluetooth Board Replacement: 5 단계, 이미지 2개 중 1개 Beats Studio 2 Wireless Bluetooth Board Replacement: 5 단계, 이미지 2개 중 2개
      • Gently pull the wire with rubber connectors off of the speaker.
      댓글 쓰기
    4. Beats Studio 2 Wireless Bluetooth Board Replacement: 6 단계, 이미지 1개 중 1개
      • Use a soldering iron to desolder the two connections.
      • For details on how to solder and desolder, refer to the How to Solder and Desolder Connections guide.
      • A soldering iron can produce very high temperatures, and can burn skin. Use with caution.
      • Note the position of the speaker in its housing, then carefully remove the faulty speaker.
      댓글 쓰기
    1. Beats Studio 2 Wireless Bluetooth Board Replacement, Bluetooth Board: 7 단계, 이미지 1개 중 1개
      • Peel off the sticker underneath the speaker.
      댓글 쓰기
    2. Beats Studio 2 Wireless Bluetooth Board Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the center screw using a Phillips #00 screwdriver.
      댓글 쓰기
    3. Beats Studio 2 Wireless Bluetooth Board Replacement: 9 단계, 이미지 1개 중 1개
      • Separate the plastic case from the rubber backing by hand or with a spudger.
      댓글 쓰기
    4. Beats Studio 2 Wireless Bluetooth Board Replacement: 10 단계, 이미지 2개 중 1개 Beats Studio 2 Wireless Bluetooth Board Replacement: 10 단계, 이미지 2개 중 2개
      • Use a Phillips #00 to remove the four screws securing the case on top of the Bluetooth board.
      댓글 쓰기
    5. Beats Studio 2 Wireless Bluetooth Board Replacement: 11 단계, 이미지 1개 중 1개
      • Use a spudger to gently pry the left headband clip to free the earphone from the hinge.
      • This picture shows this for the right earphone, but the process should be exactly the same for the left side.
      댓글 쓰기
    6. Beats Studio 2 Wireless Bluetooth Board Replacement: 12 단계, 이미지 1개 중 1개
      • Slide the front case down to separate it from the back and reveal the Bluetooth board.
      댓글 쓰기
    7. Beats Studio 2 Wireless Bluetooth Board Replacement: 13 단계, 이미지 2개 중 1개 Beats Studio 2 Wireless Bluetooth Board Replacement: 13 단계, 이미지 2개 중 2개
      • Remove the four screws from the Bluetooth board with the Phillips #00 screwdriver.
      • This will free the Bluetooth board from the back case.
      댓글 쓰기
    8. Beats Studio 2 Wireless Bluetooth Board Replacement: 14 단계, 이미지 2개 중 1개 Beats Studio 2 Wireless Bluetooth Board Replacement: 14 단계, 이미지 2개 중 2개
      • Remove the Bluetooth board from the case.
      • Remove the translucent sticker from the back of the Bluetooth board.
      댓글 쓰기
    9. Beats Studio 2 Wireless Bluetooth Board Replacement: 15 단계, 이미지 1개 중 1개
      • Use the pointed tip of a spudger to carefully push on each side of the connector to remove it from the socket.
      댓글 쓰기
    10. Beats Studio 2 Wireless Bluetooth Board Replacement: 16 단계, 이미지 1개 중 1개
      • Desolder the RYB connectors, and the connector attached to the black wire using a soldering iron.
      • For information on desoldering connections, see the How to Solder and Desolder Connections Guide.
      • The soldering iron can reach very high temperatures. Use it with caution.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jack Wilson
회원 가입일: 03/20/23
599 평판
안내서 2개를 작성함
UMass Dartmouth, Team 5-3, Ramos Spring 2023 UMass Dartmouth, Team 5-3, Ramos Spring 2023 회원
UMASSD-RAMOS-S23S5G3
3 회원들
안내서 16개를 작성함
1가이드 댓글
Hi, can you help me out with a wiring diagram to the bluetooth board, all my wires got torn loose from my old board and i do not know where to solder the new wires to which connections. If you could post a picture with which coloured wires go where , that would be most helpful, thanks.
Roger Bee_44 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 51
전체 시간: 2,940
