주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Beats Studio 2 Wireless Speaker Replacement
필요한 것
    1. Beats Studio 2 Wireless Speaker Replacement, Ear Cushion: 1 단계, 이미지 2개 중 1개 Beats Studio 2 Wireless Speaker Replacement, Ear Cushion: 1 단계, 이미지 2개 중 2개
      • Insert a spudger between the plastic part of the left headphone and the ear cushion.
      • Work the spudger around the periphery of the base of the cushion and gently pry it off the head phone.
      댓글 쓰기
    2. Beats Studio 2 Wireless Speaker Replacement: 2 단계, 이미지 3개 중 1개 Beats Studio 2 Wireless Speaker Replacement: 2 단계, 이미지 3개 중 2개 Beats Studio 2 Wireless Speaker Replacement: 2 단계, 이미지 3개 중 3개
      • Pull the rest of the cushion away from the adhesive with your hands.
      댓글 쓰기
    1. Beats Studio 2 Wireless Speaker Replacement, Speaker: 3 단계, 이미지 2개 중 1개 Beats Studio 2 Wireless Speaker Replacement, Speaker: 3 단계, 이미지 2개 중 2개
      • Using the Phillips #00 screwdriver, remove the screws holding the speaker in place.
      • If the speaker is on the side with the charging port be sure to keep the two screws holding the charging port separate.
      댓글 쓰기
    2. Beats Studio 2 Wireless Speaker Replacement: 4 단계, 이미지 1개 중 1개
      • Gently separate the speaker from the headphones.
      • Don't pull or yank the speaker from the headphones. They are connected together by wires that might be damaged.
      댓글 쓰기
    3. Beats Studio 2 Wireless Speaker Replacement: 5 단계, 이미지 2개 중 1개 Beats Studio 2 Wireless Speaker Replacement: 5 단계, 이미지 2개 중 2개
      • Gently pull the wire with rubber connectors off of the speaker.
      댓글 쓰기
    4. Beats Studio 2 Wireless Speaker Replacement: 6 단계, 이미지 1개 중 1개
      • Use a soldering iron to desolder the two connections.
      • For details on how to solder and desolder, refer to the How to Solder and Desolder Connections guide.
      • A soldering iron can produce very high temperatures, and can burn skin. Use with caution.
      • Note the position of the speaker in its housing, then carefully remove the faulty speaker.
      댓글 쓰기
결론
After soldering the new speaker, reassemble your device by following the steps in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mike Rosiello
회원 가입일: 03/20/23
325 평판
안내서 2개를 작성함
UMass Dartmouth, Team 5-3, Ramos Spring 2023 UMass Dartmouth, Team 5-3, Ramos Spring 2023 회원
UMASSD-RAMOS-S23S5G3
3 회원들
안내서 16개를 작성함
1가이드 댓글
I didn't need to replace a speaker but just touch up the solder joints, this was a great guide! Thank you!
William Pryor - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 32
전체 시간: 1,105
