주요 콘텐츠로 건너뛰기
Blink Video Doorbell Speaker Replacement
LisbethRivas_
LisbethRivas_4 다른 기여자
최종 수정일 January 3, 2025
15 - 20 분
조정
The Blink Video Doorbell is a doorbell to provide extra security to your residence by giving you an accessible view whenever necessary. The speaker is a key function of the device. It allows you to be able to hear during the video and relay a message back through the device. Refer to the troubleshooting page if there are issues with the speaker which could be connected to causes such as debris. If you need to take out the speaker, use this guide to remove and replace the speaker.
필요한 것
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Blink Video Doorbell Speaker Replacement, Battery: 1 단계, 이미지 3개 중 1개 Blink Video Doorbell Speaker Replacement, Battery: 1 단계, 이미지 3개 중 2개 Blink Video Doorbell Speaker Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Push the opening key into the small opening with the two gray buttons on the bottom of the device.
    • The device will click off the mount.
    • Push the device up from the mount and slide it off.
  2. Blink Video Doorbell Speaker Replacement: 2 단계, 이미지 3개 중 1개 Blink Video Doorbell Speaker Replacement: 2 단계, 이미지 3개 중 2개 Blink Video Doorbell Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Use your finger to slide the gray tab, located near the bottom of the device, upwards.
    • Remove the battery cover.
  3. Blink Video Doorbell Speaker Replacement: 3 단계, 이미지 3개 중 1개 Blink Video Doorbell Speaker Replacement: 3 단계, 이미지 3개 중 2개 Blink Video Doorbell Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
    • Do not mix used and new batteries or batteries of different types (for example, lithium and alkaline batteries).
  4. Blink Video Doorbell Speaker Replacement, Back Panel: 4 단계, 이미지 3개 중 1개 Blink Video Doorbell Speaker Replacement, Back Panel: 4 단계, 이미지 3개 중 2개 Blink Video Doorbell Speaker Replacement, Back Panel: 4 단계, 이미지 3개 중 3개
    • Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
    • Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
    • Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
  5. Blink Video Doorbell Speaker Replacement, Speaker: 5 단계, 이미지 3개 중 1개 Blink Video Doorbell Speaker Replacement, Speaker: 5 단계, 이미지 3개 중 2개 Blink Video Doorbell Speaker Replacement, Speaker: 5 단계, 이미지 3개 중 3개
    • Remove the three 6 mm screws from the upper part of the motherboard using a JIS #1 screwdriver.
    • Use an opening tool to release the motherboard from the device.
  6. Blink Video Doorbell Speaker Replacement: 6 단계, 이미지 3개 중 1개 Blink Video Doorbell Speaker Replacement: 6 단계, 이미지 3개 중 2개 Blink Video Doorbell Speaker Replacement: 6 단계, 이미지 3개 중 3개
    • Use tweezers to detach the white connector from the adapter on the motherboard.
    • Remove the speaker.
결론
작성자
4다른 기여자 명과 함께
LisbethRivas_
회원 가입일: 10/18/24
87 평판
안내서 1개를 작성함
UMass Dartmouth, Team 1-1, Konn Fall 2024 UMass Dartmouth, Team 1-1, Konn Fall 2024 회원
UMASSD-KONN-F24S1G1
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 14
전체 시간: 100
