주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Contixo V8 Battery Replacement
필요한 것
    1. Contixo V8 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Find the edge of the tablet, where the front panel meets the sides. Use the plastic opening tools to pry the panels apart.
      • The back and front of the device can be reattached by lining them up and pushing around the edges. Be sure to do this around the full perimeter of the device to ensure proper connection. You will hear a popping sound; this is the plastic sliding back into place, and is normal.
      • Lift the face of the tablet.
      댓글 쓰기
    2. Contixo V8 Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Use the spudger tool to separate the battery from metal screen frame; there will be a small strip of double-sided tape holding it in place. A blue iFixit opening tool would also work for this purpose.
      댓글 쓰기
    3. Contixo V8 Battery Replacement: 3 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Anti-Static Wrist Strap
      $7.95
      • Press the soldering tip to the 3 connection points to detach the motherboard and the battery. See this guide for information and tips on soldering and desoldering.
      • You will need to reattach these connection points when reassembling your device with the soldering iron. This guide will walk you through how to do that. Be sure to attach the positive and negative wires to the correct connections.
      • Exercise caution when desoldering the battery, especially if you've had issues with the device's power which could point to it being faulty. Consider using an anti-static wrist strap when working with the battery and its cables. See this guide for information on swollen batteries, another thing to look out for.
      • The battery is now disconnected and ready to be replaced.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
phil_sc_03
회원 가입일: 09/08/23
231 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 55
전체 시간: 1,206
