주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Contixo V8 Internal Speaker Replacement
필요한 것
    1. Contixo V8 Internal Speaker Replacement, Internal Speaker: 1 단계, 이미지 1개 중 1개
      • Find the edge of the tablet, where the front panel meets the sides. Use the plastic opening tools to pry the panels apart.
      • The back and front of the device can be reattached by lining them up and pushing around the edges. Be sure to do this around the full perimeter of the device to ensure proper connection. You will hear a popping sound; this is the plastic sliding back into place, and is normal.
      • Lift the face of the tablet.
      댓글 쓰기
    2. Contixo V8 Internal Speaker Replacement: 2 단계, 이미지 2개 중 1개 Contixo V8 Internal Speaker Replacement: 2 단계, 이미지 2개 중 2개
      • Press the soldering tip to the connection point to detach the speaker from the motherboard. See this guide for information and tips on soldering and desoldering.
      • You will need to reattach these connection points when reassembling your device with the soldering iron. This guide will walk you through how to do that. Be sure to attach the positive and negative wires to the correct points when resoldering the connections.
      • You have now detached the internal speaker and the new speaker is ready to be attached.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
phil_sc_03
회원 가입일: 09/08/23
231 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 436
