주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Contixo V8 Motherboard Replacement
필요한 것
  1. Contixo V8 Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 Contixo V8 Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Find the edge of the tablet, where the front panel meets the sides. Use the plastic opening tools to pry the panels apart.
    • The back and front of the device can be reattached by lining them up and pushing around the edges. Be sure to do this around the full perimeter of the device to ensure proper connection. You will hear a popping sound; this is the plastic sliding back into place, and is normal.
    • Lift the face of the tablet.
    댓글 쓰기
  2. Contixo V8 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the three 1.4 mm screws from the motherboard with the Phillips size #000 screwdriver.
    댓글 쓰기
  3. Contixo V8 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Contixo V8 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Contixo V8 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • The cable marked in red is locked into place by two dark pull tabs; pull each away from the cream connection port towards the edge of the tablet. Gently remove the cable once the tabs are in the open position.
    • This cable must be reattached by inserting its end into the port with a moderate amount of force (to ensure proper connection) and then sliding both dark locking tabs back into place against the cream port.
    • The cables marked in orange are known as zero-insert force cables. To remove the connection, flip up the dark tab and gently pull the ribbon away.
    • ZIF ribbon cables must be reattached by sliding the cable into place (without force, as implied by the name) and flipping the dark locking tab back into place. Please see this guide if you're having issues reattaching the ZIF cables.
    댓글 쓰기
  4. Contixo V8 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Contixo V8 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Contixo V8 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Use the spudger tool to break the adhesive holding the battery down and lift it off of the base of the tablet. One of the blue iFixit opening tools can also be used in place of the spudger.
    • Press the soldering tip to the 3 connection points to detach the motherboard and the battery. See this guide for information and tips on soldering and desoldering.
    • You will need to reattach these connection points when reassembling your device with the soldering iron. This guide will walk you through how to do that.
    • Exercise caution when desoldering the battery, especially if you've had issues with the device's power which could point to it being faulty. Consider using an anti-static wrist strap when working with the battery and its cables.
    댓글 쓰기
  5. Contixo V8 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the motherboard from the base of the device. It is now ready to be replaced.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Erin
회원 가입일: 09/08/23
247 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 37
전체 시간: 706
