Dell Inspiron 13-7347 Motherboard Replacement
This guide is to help anyone looking to remove and replace the Dell Inspiron 17-7347 laptop motherboard. This will be a step-by-step process of replacing the motherboard. It will require several tools that you will want to gather before opening the computer. There are several things you need to know before replacing a motherboard. Step 1) Make sure your data is backed up on a cloud or another computer. Step 2) Make sure you have the correct tools needed for the job. Step 3) When replacing and using the tools be careful not to strip or break the parts.
Make sure to follow the steps carefully and correctly.
Flip the device over, so that the back is facing up.
Using a Phillips screwdriver, remove the 10 2.5mm x 8mm screws
Use the suction cup to lift off the back case.
Using a Phillips #0 screwdriver, loosen and remove the two 3.0 mm hard drive screws.
Lift the hard drive up and out of the device.
Using a Phillips #0 screwdriver, loosen the three 3.0 mm heat sink screws.
Remove the Heat Sink.
Using a Phillips #0 screwdriver, remove the 5.0 mm DC jack screw.
Unplug and remove the DC jack.
