주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7353 Battery Replacement
Andrew Parkhurst
Andrew Parkhurst4 다른 기여자
최종 수정일 November 19, 2020
5 - 10 분
매우 쉬움
If the Dell Inspiron 13-7353 is experiencing a corrupted battery, short battery life, physical damage, or any problems requiring the battery to be replaced, use the guide below to replace the battery.
Ensure the battery is still experiencing problems before working on the components.
Before working on the device, power down the computer and clear all debris once the back of the device has been opened.
필요한 것
부품
도구
더보기...
  1. Dell Inspiron 13-7353 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Using the Phillips #0 screwdriver, remove ten 4 mm screws from the back panel.
    • Lift and remove the back panel.
  2. Dell Inspiron 13-7353 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery to the laptop.
  3. Dell Inspiron 13-7353 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery up and out of the computer.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 25
전체 시간: 1,138
