주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5584 Bottom Cover Replacement
Sam Vorn
Sam Vorn2 다른 기여자
최종 수정일 May 9, 2022
3 - 5 분
쉬움
Use this guide to assist in removing the bottom cover on your Dell Inspiron 15 5584 laptop.
The bottom cover serves as a guard to protect the sensitive hardware components within the machine and acts as a surface to place the laptop as well. All hardware issues within the Dell Inspiron 15 5584 require you to remove the bottom cover to resolve them.
Before using this guide, make sure to review the troubleshooting page and confirm what issue you are having with your device. Keeping the bottom cover off for too long may result in components becoming damaged. Furthermore, when removing the bottom cover, clicking and snapping sounds are normal; however, the bottom cover is made of hard plastic that can easily snap.
필요한 것
도구
  1. Dell Inspiron 15 5584 Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Make sure to turn off and unplug your laptop before starting.
    • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
  2. Dell Inspiron 15 5584 Bottom Cover Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron 15 5584 Bottom Cover Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron 15 5584 Bottom Cover Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
    • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
    • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
  3. Dell Inspiron 15 5584 Bottom Cover Replacement: 3 단계, 이미지 2개 중 1개 Dell Inspiron 15 5584 Bottom Cover Replacement: 3 단계, 이미지 2개 중 2개
    • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
    • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
    • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
  4. Dell Inspiron 15 5584 Bottom Cover Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 15 5584 Bottom Cover Replacement: 4 단계, 이미지 2개 중 2개
    • Gently pry off the bottom cover from the laptop.
    • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
결론
작성자
2다른 기여자 명과 함께
Sam Vorn
회원 가입일: 03/29/22
977 평판
안내서 9개를 작성함
UMass Dartmouth, Team 1-1, Mellen Spring 2022 UMass Dartmouth, Team 1-1, Mellen Spring 2022 회원
UMASSD-MELLEN-S22S1G1
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 20
전체 시간: 463
