주요 콘텐츠로 건너뛰기
Dell Inspiron 3552 Hard Drive  Replacement Part 1
Jordon Dozier
Jordon Dozier2 다른 기여자
최종 수정일 July 26, 2024
15 분
조정
문법 검토
헷갈리는 텍스트
커뮤니티-기여 안내서
part 2: Dell Inspiron 3552 Hard drive Replacement part 2 - iFixit Repair Guide
필요한 것
부품
  1. Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the battery: 1 단계, 이미지 1개 중 1개
    • Close the display and turn the computer over
    • Slide the battery-release latch to the unlocked position
    • Lift the battery at an angle and remove the battery from the battery bay
  2. Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing optical drive: 2 단계, 이미지 1개 중 1개
    • Remove the screw that secures the optical-drive assembly to the base cover.
    • Using a plastic scribe, push the optical-drive assembly out of the optical-drive bay.
    • Pull the optical-drive assembly out of the optical-drive bay.
  3. Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing keyboard: 3 단계, 이미지 2개 중 1개 Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing keyboard: 3 단계, 이미지 2개 중 2개
    • Turn on the computer over and open the display
    • Using a plastic scribe, gently release the tabs that secure the keyboard to the palm-rest assembly
    • Slide the keyboard up to release it from the slots on the palm-rest assembly.
    • Carefully turn the keyboard over and place it on the palm-rest assembly
  4. Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the base cover: 4 단계, 이미지 3개 중 1개 Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the base cover: 4 단계, 이미지 3개 중 2개 Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the base cover: 4 단계, 이미지 3개 중 3개
    • Open the display and remove the screws that secure the palm-rest assembly to the base cover from its connector on the system board
    • Open the latch and disconnect the optical-drive cable from its connector on the system board
    • Close the display and turn the computer over.
    • Remove the screws that secure the base cover to the palm-rest assembly
    • Using your fingertips, gently pry the base cover off the palm-rest assembly
  5. Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing the base part 2: 5 단계, 이미지 1개 중 1개
    • Release the optical-drive interposer from the tabs on the base cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jordon Dozier
회원 가입일: 02/10/21
1,663 평판
안내서 12개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 18
전체 시간: 948
