Doxy Personal Massager Bearing and Screw Replacement
A visual guide for a manual i created recently
how to tear down and replace the bearings on a Doxy massager (original and die-cast editions) this may work on the new Doxy Die-Cast R which has internal batteries, but i haven't got one to tear down yet
필요한 것
부품
도구
더보기...
Use either prying force, impact, or torsion to break the glue under the metal collar
This may damage the collar visibly,
This will not stick back together, you will need some rubberised sealant or glue to put it back together
Gently pry the motor and neck from the body
Slide the neck up towards the counterweight
Press the new bearings into place
Be sure to only put force on the center bearing race as pressing from the outside race may damage the bearing
using one of the old bearings can help in distributing the load evenly
Replace the rubber dampers
You should now have a working Doxy with new Bearings!
some lubricant may be used to free up the bearings if the grease they come with is too thick
but be careful not to lubricate the rubber collars as they can slip and increase friction on the counterweight
