주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Edifier W820NB Plus I/O Board Replacement
필요한 것
    1. Edifier W820NB Plus I/O Board Replacement, Ear Pads: 1 단계, 이미지 1개 중 1개
      • Start with the headphones face up and the earpads visible.
      댓글 쓰기
    2. Edifier W820NB Plus I/O Board Replacement: 2 단계, 이미지 2개 중 1개 Edifier W820NB Plus I/O Board Replacement: 2 단계, 이미지 2개 중 2개
      • Hold the driver housing in one hand and insert an opening tool into the seam between the earpad and driver housing.
      댓글 쓰기
    3. Edifier W820NB Plus I/O Board Replacement: 3 단계, 이미지 2개 중 1개 Edifier W820NB Plus I/O Board Replacement: 3 단계, 이미지 2개 중 2개
      • With your inserted opening tool, pry around the perimeter of the ear pad until it fully releases.
      • Repeat this procedure for the other side if necessary.
      댓글 쓰기
    4. Edifier W820NB Plus I/O Board Replacement: 4 단계, 이미지 1개 중 1개
      • Repeat for the other side if necessary.
      댓글 쓰기
    1. Edifier W820NB Plus I/O Board Replacement, Drivers: 5 단계, 이미지 1개 중 1개
      • Identify the driver you wish to replace.
      • This guide will use the left driver as an example but the same steps can be mirrored when replacing or removing the right driver. The battery is under the left driver, while the motherboard and daughterboard are under the right driver.
      댓글 쓰기
    2. Edifier W820NB Plus I/O Board Replacement: 6 단계, 이미지 2개 중 1개 Edifier W820NB Plus I/O Board Replacement: 6 단계, 이미지 2개 중 2개
      • Remove all five 5 mm Phillips #0 screws that secure the driver assembly.
      댓글 쓰기
    3. Edifier W820NB Plus I/O Board Replacement: 7 단계, 이미지 3개 중 1개 Edifier W820NB Plus I/O Board Replacement: 7 단계, 이미지 3개 중 2개 Edifier W820NB Plus I/O Board Replacement: 7 단계, 이미지 3개 중 3개
      • Note that the wires for the drivers are on the outermost edge. Try to avoid pushing or cutting them when taking the driver out.
      • Insert a Jimmy in the seam between the driver assembly and driver housing.
      • Rotate the Jimmy along the entire perimeter of the innermost edge to pry it out of place.
      댓글 쓰기
    4. Edifier W820NB Plus I/O Board Replacement: 8 단계, 이미지 2개 중 1개 Edifier W820NB Plus I/O Board Replacement: 8 단계, 이미지 2개 중 2개
      • Gently remove the driver assembly from the rest of the headphone, with care not to strain the connected wire.
      댓글 쓰기
    5. Edifier W820NB Plus I/O Board Replacement: 9 단계, 이미지 2개 중 1개 Edifier W820NB Plus I/O Board Replacement: 9 단계, 이미지 2개 중 2개
      • Skip this step if you are completing a battery replacement.
      • Repeat the procedure for the other driver if necessary.
      • Desolder the four driver connections from the motherboard.
      • Remove the driver assembly.
      댓글 쓰기
    1. Edifier W820NB Plus I/O Board Replacement, I/O Board: 10 단계, 이미지 3개 중 1개 Edifier W820NB Plus I/O Board Replacement, I/O Board: 10 단계, 이미지 3개 중 2개 Edifier W820NB Plus I/O Board Replacement, I/O Board: 10 단계, 이미지 3개 중 3개
      • Use a Philllips #0 screwdriver to remove the 2 mm screws that secure the I/O board.
      댓글 쓰기
    2. Edifier W820NB Plus I/O Board Replacement: 11 단계, 이미지 3개 중 1개 Edifier W820NB Plus I/O Board Replacement: 11 단계, 이미지 3개 중 2개 Edifier W820NB Plus I/O Board Replacement: 11 단계, 이미지 3개 중 3개
      • Pry out the power and volume buttons cover using a Jimmy.
      댓글 쓰기
    3. Edifier W820NB Plus I/O Board Replacement: 12 단계, 이미지 2개 중 1개 Edifier W820NB Plus I/O Board Replacement: 12 단계, 이미지 2개 중 2개
      • Pull the daughter board out.
      • Note that the connections (both in the front and back) will need to be desoldered.
      댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Happy Zhang
회원 가입일: 03/21/25
438 평판
안내서 4개를 작성함
UMass Dartmouth, Team 2-7, Botvin Spring 2025 UMass Dartmouth, Team 2-7, Botvin Spring 2025 회원
UMASSD-BOTVIN-S25S2G7
3 회원들
안내서 23개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 36
전체 시간: 602
