주요 콘텐츠로 건너뛰기
Framework Laptop 16" Battery Replacement
Alex Diaz-Kokaisl
Alex Diaz-Kokaisl
최종 수정일 September 18, 2024
10 - 15 분
쉬움
추천 가이드
Use this guide to replace the battery in your Framework 16" laptop.
Before starting this repair, we recommend discharging your battery to 25% to help make it easier to dispose as e-waste.
Note: the laptop used in this guide is a generic setup of one US keyboard, one numpad module, and two touchpad spacers. Your setup might vary, but the procedure should remain the same.
필요한 것
도구
  1. Framework Laptop 16" Battery Replacement, Before you begin: 1 단계, 이미지 2개 중 1개 Framework Laptop 16" Battery Replacement, Before you begin: 1 단계, 이미지 2개 중 2개
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
    • Framework recommends that you put your laptop into battery disconnect mode in the BIOS whenever removing the battery. Read how to do that here.
    • To disable this mode, click here.
  2. Framework Laptop 16" Battery Replacement, Unlock the Input Modules: 2 단계, 이미지 3개 중 1개 Framework Laptop 16" Battery Replacement, Unlock the Input Modules: 2 단계, 이미지 3개 중 2개 Framework Laptop 16" Battery Replacement, Unlock the Input Modules: 2 단계, 이미지 3개 중 3개
    • Use your fingernail to pull out the two Input Module latches and unlock them.
    • The latch will show red if it's unlocked.
  3. Framework Laptop 16" Battery Replacement, Remove the touchpad spacers: 3 단계, 이미지 3개 중 1개 Framework Laptop 16" Battery Replacement, Remove the touchpad spacers: 3 단계, 이미지 3개 중 2개 Framework Laptop 16" Battery Replacement, Remove the touchpad spacers: 3 단계, 이미지 3개 중 3개
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  4. Framework Laptop 16" Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Repeat the same procedure for the other touchpad spacer.
  5. Framework Laptop 16" Battery Replacement, Remove the touchpad: 5 단계, 이미지 3개 중 1개 Framework Laptop 16" Battery Replacement, Remove the touchpad: 5 단계, 이미지 3개 중 2개 Framework Laptop 16" Battery Replacement, Remove the touchpad: 5 단계, 이미지 3개 중 3개
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  6. Framework Laptop 16" Battery Replacement, Remove the keyboard: 6 단계, 이미지 3개 중 1개 Framework Laptop 16" Battery Replacement, Remove the keyboard: 6 단계, 이미지 3개 중 2개 Framework Laptop 16" Battery Replacement, Remove the keyboard: 6 단계, 이미지 3개 중 3개
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard.
    • Lift the pull tabs until the keyboard magnets release.
    • Remove the keyboard.
    • During reassembly, make sure the keyboard is seated properly on its alignment pegs and sits evenly with the edges of the laptop.
  7. Framework Laptop 16" Battery Replacement, Remove the numpad: 7 단계, 이미지 3개 중 1개 Framework Laptop 16" Battery Replacement, Remove the numpad: 7 단계, 이미지 3개 중 2개 Framework Laptop 16" Battery Replacement, Remove the numpad: 7 단계, 이미지 3개 중 3개
    • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
    • Grip the pull tab at the bottom of the numpad.
    • Lift the pull tab until the numpad magnets release.
    • Remove the numpad.
    • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  8. Framework Laptop 16" Battery Replacement, Disconnect the midframe cable: 8 단계, 이미지 2개 중 1개 Framework Laptop 16" Battery Replacement, Disconnect the midframe cable: 8 단계, 이미지 2개 중 2개
    • Grip the black pull tab on the midframe cable press connector.
    • Lift up to disconnect the midframe cable.
  9. Framework Laptop 16" Battery Replacement, Loosen the midframe screws: 9 단계, 이미지 2개 중 1개 Framework Laptop 16" Battery Replacement, Loosen the midframe screws: 9 단계, 이미지 2개 중 2개
    • The midframe screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
    • Use a T5 Torx screwdriver to loosen the 16 captive screws securing the midframe.
    • During reassembly, follow the order (starting with 2) to reinstall the screws across the midframe evenly.
  10. Framework Laptop 16" Battery Replacement, Remove the midframe: 10 단계, 이미지 2개 중 1개 Framework Laptop 16" Battery Replacement, Remove the midframe: 10 단계, 이미지 2개 중 2개
    • Use your fingernail to lift the bottom edge of the midframe enough to grip it with your fingers.
  11. Framework Laptop 16" Battery Replacement: 11 단계, 이미지 2개 중 1개 Framework Laptop 16" Battery Replacement: 11 단계, 이미지 2개 중 2개
    • Lift the midframe off the laptop and remove it.
    • During reassembly, make sure the midframe sits evenly on its alignment pegs before tightening the screws.
  12. Framework Laptop 16" Battery Replacement, Loosen the battery screws: 12 단계, 이미지 2개 중 1개 Framework Laptop 16" Battery Replacement, Loosen the battery screws: 12 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to loosen the three captive screws securing the battery.
  13. Framework Laptop 16" Battery Replacement, Remove the battery: 13 단계, 이미지 3개 중 1개 Framework Laptop 16" Battery Replacement, Remove the battery: 13 단계, 이미지 3개 중 2개 Framework Laptop 16" Battery Replacement, Remove the battery: 13 단계, 이미지 3개 중 3개
    • Grip the black pull tab at the top of the battery.
    • Lift the pull tab to disconnect the battery connector.
    • Remove the battery.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
162,690 평판
안내서 769개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,474개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 61
전체 시간: 916
