주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fujitsu LIFEBOOK P7010D Hard Drive Replacement
필요한 것
  1. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place the laptop upside down on a table.
    댓글 쓰기
  2. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the battery (the grey block). Find the two tabs on one end of the battery, as pictured.
    • Using two fingers, press both tabs down at once until they are fully depressed.
    댓글 쓰기
  3. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • While holding the tabs down, slowly pivot the battery up.
    • The battery is now free and safe to pull out.
    댓글 쓰기
  4. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: 4 단계, 이미지 3개 중 1개 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: 4 단계, 이미지 3개 중 2개 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: 4 단계, 이미지 3개 중 3개
    • Push the tab down as far as possible using your finger or opening tool to unlock the disc drive.
    • While still holding the tab down, use your other hand to pull out the disc drive straight out of its place.
    댓글 쓰기
  5. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2개 중 1개 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2개 중 2개
    • On the bottom of the laptop, find the two bottom-plate screw holes near the disc drive. Parallel to them is a 2.4mm screw (second photo).
    • After locating the 2.4mm screw, use a Phillips #0 screwdriver to unscrew it.
    댓글 쓰기
  6. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Flip the laptop over and open it facing you.
    • The cover is connected to the inner computer with an aluminum strip, so be careful lifting it.
    • Use a plastic opening tool to lift the bottom black cover on both sides.
    • For the proceeding steps, put on an anti-static wrist strap to protect the delicate circuitry inside the computer. To learn how to use the anti-static wrist strap, click here.
    댓글 쓰기
  7. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 7 단계, 이미지 3개 중 1개 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 7 단계, 이미지 3개 중 2개 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 7 단계, 이미지 3개 중 3개
    • The hard drive is connected with a strip, so be careful when lifting it out.
    • Once the black cover is lifted, gently flip it and set it on the keyboard.
    • Locate the disc drive on the right side, as pictured.
    • Using two fingers and the clear plastic handles on the top, gently lift it out. Place it on the side of the laptop.
    댓글 쓰기
  8. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 8 단계, 이미지 3개 중 1개 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 8 단계, 이미지 3개 중 2개 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 8 단계, 이미지 3개 중 3개
    • Flip the hard drive on its side.
    • The pins connected to the hard drive are extremely fragile. Take care in handling the next few steps.
    • Hold the hard drive and insert a plastic opening tool, preferably a wider one, in between the black pin holder and the hard drive.
    • Gently wiggle the black pin holder back and forth, on each side, until it comes off.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Nicholas Ross
회원 가입일: 01/20/12
207 평판
안내서 7개를 작성함
Cal Poly, Team 10-31, Amido Winter 2012 Cal Poly, Team 10-31, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G31
5 회원들
안내서 21개를 작성함
1가이드 댓글
hai sir..please help me..how to replacement hdd lifebook PH770/5AN ? can you answer to my email antogantengnian@gmail.com..thanks a lot
anto adhitya - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 49
전체 시간: 6,277
